2001 Honda Accord - difficulty shifting from park
Old 04-30-2012 | 09:48 AM
drfence's Avatar
Default 2001 Honda Accord - difficulty shifting from park
After starting my car I have been having difficulty shifting from park to drive. Sometimes I'll sit there for a minute or more until I'm able to shift. Sometimes I turn the car on / off and I can then shift ... sometimes that doesn't work either.
Old 04-30-2012 | 01:31 PM
Is the shift lever locked?
There is a function that locks the shift lever in PARK if you're not pressing the brake pedal. Could it be that the brake-lamp switch (at the brake pedal) needs to be adjusted?
Old 04-30-2012 | 03:46 PM
drfence's Avatar
Yes the shift lever is locked.
I'll have to look down at the switch.
Old 04-30-2012 | 06:10 PM
Same switch operates the brake lamps and the shift interlock, so you can check it out by watching when the brake lamps come on.
Switch broken? Unplugged?
I think there's some kind of adjustment of the switch position in its bracket. Two nuts, either side of the bracket.
rjpjnk
06-16-2016 12:40 PM
D Vasquez
09-01-2011 11:43 PM
campervan12000
06-15-2011 08:23 AM
techman41973
05-21-2011 09:05 AM
poser_pilot6
11-24-2006 06:58 AM
