2001 Honda Accord LX A/C trigger when change air flow to "DEFROST" position.
I have a 2001 Honda Accord LX, when I turn on the heat and set the air flow to defrost or defrost/feet position it trigger the A/C to turn on too and sometimes my LCD clock just keep flickering and then the clock were off. I removed the radio and check the wires everything appear to be good conditions, does anyone have any clue what's going on? I appreciate any helps
Thanks
Moshlub
Thanks
Moshlub
Welcome!
The AC is supposed to come on when you select defrost, to dehumidify the air. You CAN switch it off, unlike the 2003+ cars where you're unable to switch it off.
The LCD clock is probably a separate issue. Is it the illumination that flickers, or the digits themselves?
Is that right? wow, I didn't know that was normal, I though something's wrong with it, this is the first Honda I ever owned. . .
As for the clock, I don't really know how to explain it, sometimes it just start flickering on/off and all the clock elements lit up and went off, etc, if I punch the dash near the clock sometimes it stop for a few minutes.
dylan1986
05-29-2015 08:45 PM
AccordAnimal
08-11-2010 08:04 AM
