2002 honda/with new motor
Old 10-17-2012 | 12:24 PM
chadwickh's Avatar
Default 2002 honda/with new motor
I have a 2002 honda accord, we replaced the motor, when we tried to start the car the check engine light came on, we scanned it with a computer and the code that we got was p-1706. When you try to crank it the d-4 light comes on and i don't know what to do next. This is my car that i drive to work and my job is about 60 miles one way, i have a borrowed car so i really need to get my car back on the road. Any help will be greatly appreciated.
Old 10-17-2012 | 12:32 PM
shipo's Avatar
Which engine and transmission? Is the replacement engine new or used?
Old 10-18-2012 | 03:12 AM
Thumbs up
Yes , we need answers for help..put that info into your signature area please..Thanks SHIPO
Old 10-18-2012 | 12:44 PM
chadwickh's Avatar
used motor same tran. its auto.
Old 10-18-2012 | 12:46 PM
chadwickh's Avatar
4 cy. im sorry, not used to using computer.
Old 10-18-2012 | 12:52 PM
shipo's Avatar
Who did you buy the motor from? Did you see it running before you bought it?
Old 10-18-2012 | 01:08 PM
P1706 TCM A/T Gear Position Switch Circuit Open
Did you check that gear position switch is connected? This fault would likely be cause of D4 light flashing also. W/O the proper trans position, the ECU may prevent starting.
Old 10-18-2012 | 01:26 PM
shipo's Avatar
Oh nicely done! Given that I almost always approach stuff like this with the mentality of the manual transmission bigot that I am, I completely missed the d-4 reference. Pat yourself on the back.
Old 10-18-2012 | 08:48 PM
chadwickh's Avatar
i have run the engine by jumping out the starter and drove the car down the road. the tranny shifts fine in every gear but when you put it in park it want come out and when you cut it off it want start. the d4 light stays on and the code p1706 comes up when you scan the computer.I have checked the gear position senser it is pluged.the motor come from a salvage yard the man who runs it knows my dad .the wiring harness was already on the motor so i looked it over very well and we used it. the harness and pluges looked good no cuts and brooken plugs.
Old 10-19-2012 | 09:12 PM
I HATE ELECTRICAL issues......
Check the #9 (number by my manual) 7.5 amp fuse in the drivers underdash fuse panel with a volt meter and KO.
Do the brake lights come on when you press the brake pedal?
Woodall
03-04-2014 05:21 AM
Doublel
03-11-2013 08:57 AM
brennonm
09-01-2008 11:42 AM
accord4sroy
08-22-2007 12:24 PM
ncpmedic
10-17-2005 03:48 PM
