2003 2.0 Auto Accord Rear Caliper
Old 08-29-2010 | 12:58 PM
Taffytim's Avatar
Default 2003 2.0 Auto Accord Rear Caliper
Hello,
My rear calliper has been binding for ages and its now worn the pad out and grinding metal on metal so i'd better get to changing it.
When sourcing a new caliper are there other years of accords that share the same caliper as mine? Or other cars that will have the same?
Thanks
Tim
Old 08-29-2010 | 08:08 PM
piggylover1985's Avatar
I'm not sure on the interchangeability of the rear caliper on 03, but i just thought it might be hard to find an 03 accord with the 2.0 engine. They're kindda rare.
Old 08-30-2010 | 06:03 AM
Taffytim's Avatar
Ok, thanks. You didn't come close to answer my question but at least you stated that at the start of your post and didn't give me any false hope :-P
Old 08-30-2010 | 04:41 PM
Piggylover... smaller displacement engines are pretty common in England & elsewhere outside of USA.
Old 08-30-2010 | 04:51 PM
Gotcha
Old 08-30-2010 | 11:49 PM
kris_loehr's Avatar
Did you check the sliders for ease of moment as a caliper failing isn’t common.
Old 08-31-2010 | 05:31 AM
Taffytim's Avatar
No I didn't, my knowledge isnt that good on calipers, how do I check this?
Old 08-31-2010 | 09:38 AM
Here's a USA rear caliper, UK is probably almost identical.
There's only one piston, so the body of the caliper has to slide to apply pressure on the outboard pad. The slide pins (#17 & 29) should be greased & they should slide easily. Remove the bolts #34 & then the caliper body should slide off with a little persuasion - then you can check the slide pins for smooth movement.
The brake pads #9 should fit nicely into the caliper bracket. Should NOT be wedged tightely in there, because they need to release when you take your foot off the brake pedal. Sometimes I have needed to file off a little material, usually no more than the thickness of the paint. A bit of brake grease on the top & bottom of the pads is good, where they fit into the caliper bracket. DO NOT get grease onto the braking surface of the pads & rotors.
Old 09-01-2010 | 01:48 PM
Taffytim's Avatar
thanks for that Jim, could you send a link to the pic or repost as its not showing, ta muchly
Old 09-01-2010 | 04:23 PM
http://www {dot} hondaautomotiveparts {dot} com/auto/jsp/mws/catimgs/14sda01_b1910.png
(I made it so it's NOT an active link 'cause they aren't a sponsor here)
or go to hondaautomotiveparts dot com
click on PARTS
put in your car's information - actually make something up because they don't have UK cars
Select REAR BRAKE (DISK) as the category
Quick Reply: 2003 2.0 Auto Accord Rear Caliper
