2003 AC is out
Old 07-26-2007 | 09:23 AM
louie's Avatar
Default 2003 AC is out
about a month ago a friend of mine kept messing with my passenger AC ****. He'd make it go to the highest tempeture and after iwould press the "DUAL" button to make it go back to the my(driver's side)original setting which was like 58 degrees... after about six times the AC just stopped working.. to me it seems like we blew out a fuse? if so what fuse might that be? Please help.. i live in a desert town and the dealership wants to charge me 185$ just to diagnose it, not to mention i have a 100$ deductable on my warranty... plus they cant tell me if my warranty will cover the cost to fix it until after they diagnose it.
i have a 2003 accord ex.
Old 07-26-2007 | 11:12 AM
00AccordLX5spd's Avatar
Registered User
Default RE: 2003 AC is out
I would think there should be a fuse diagram somewhere in your owner's manual, but I am not sure. Whip out your manual and give it a once-over. Or maybe the fuse covers have diagrams showing which fuse is which. If that is not the case, I would disconnect my battery (make sure you have the radio code if yours has anti theft) and just start pulling fuses to check if one is burned out. When you pull each fuse, check it, then replace it before pulling another. You don't want to get confused as to which fuse goes where.
This could be totally off though.I am no A/C pro by any means. We have a few members on here who know a lot about A/C systems. Hopefully one of them will see your dilemma and respond with a diagnosis procedure.
Old 07-26-2007 | 02:16 PM
smaglik's Avatar
it could jsut need to be reset. try pullin the positive battery cable for 15 min or so...make sure you have your radio code.
Old 07-26-2007 | 03:35 PM
To help narrow down the possible problems, have an assistant turn on the A/C while you look in the hood.
Let us know if both fans turn on and if the compressor clutch engages.
Old 07-26-2007 | 05:36 PM
louie's Avatar
nothing happens at all to the fans or to the compressor clutchwhen i press the ac button.. what i have noticed is when i drive(only when the car is in motion), if i turn the **** clockwise(hotter temp) hot air will come out the vents... and if i turn the **** back to a cooler temp,just normal air will come in.. that is why i thinki need to change the circuit breaker for the faninside the hood fuse box.. the problem is i dont have the owners manual... but i have two main breakers that might be the culprits.. one has a picture of a snowflake, the other a picture of a fan.. i'm willing to try any suggestions before taking it in to the dealer.. i just dont have six hundred dollars to spend.
Old 07-26-2007 | 05:39 PM
louie's Avatar
imma try that... the fuses all look fine.. i think it mighta circuit breakers.
Old 07-26-2007 | 05:40 PM
Registered User
You should smack that friend of yours upside the head for breaking it[sm=chairshot.gif] then steal his credit card. Or you could pimp out his sister. Pay the dealership with that.
Old 07-26-2007 | 05:45 PM
louie's Avatar
hahah..i should..!! i've been driving in a moving oven for a while cuz of him...imma try to see what his sister is doing this weekend.
Old 07-26-2007 | 05:55 PM
Registered User
Sounds like a plan to me....[sm=pimp.gif]
rjaccord
06-17-2017 01:07 PM
Cody Is Cool
11-28-2016 11:02 PM
mishakol129
11-28-2011 06:51 AM
danh
10-17-2011 08:11 AM
Mike05af
01-24-2009 08:08 PM
Quick Reply: 2003 AC is out
