2003 Accord alarm issue (factory installed)
Old 02-08-2012 | 08:11 AM
Outdoorstom's Avatar
Default 2003 Accord alarm issue (factory installed)
My accord has developed an intermittent problem of the alarm sounding for no apparent reason. It happened a month ago, then not again until a couple days ago. I took it to a dealer yesterday and they we're not able to duplicate it. They told me they could run a test on it for $189.00 and it would take an hour. I had my 81 year old mother with me and we had already been there an hour and a half, so I declined. The service advisor told me if I don't use the fob to lock the car the alarm won't arm. I just want to make sure this is accurate. If I use the door lock switch on the door as I exit the vehicle, does that arm it? How about if I manually push the door locks down? I don't mind not having an alarm system, I just want to be able to lock it without worrying about it activating in the middle of the night. Thanks in advance for any advice you can offer!
Old 02-08-2012 | 01:03 PM
You will need to check your owner's manual for details of arming system and locking doors w/o arming. Some systems will automatically arm once doors are locked. Some trial/error testing would establish the pattern.
I once had a similar problem on 94 EX factory alarm and problem eventually was traced to weak battery. Car would start fine, but battery voltage would decline to a point where alarm would go off. If you have original battery, this could be the problem.
Old 02-08-2012 | 03:19 PM
Thanks for the feedback....much appreciated.
Old 02-08-2012 | 08:49 PM
One more thing if everything else checks out.
The hood switch on these is "kind of " known for going out. Could be grease build up, ect.....if the issue is still there try cleaning the contacts with something, re-lube and see what you have. Many have just removed the wires figuring they have to get in the car to open the hood.....just my two cents.
prkarpi
05-30-2009 03:58 AM
mgavin129
09-12-2008 11:49 PM
trukid21
04-24-2007 01:03 AM
htec
10-04-2006 09:43 AM
