2003 Accord EX accessory belt slipping why
Old 12-09-2009 | 12:58 AM
kris_loehr's Avatar
Default 2003 Accord EX accessory belt slipping why
On my 2003 Accord EX 4 cylinder the new Honda accessory belt slipped for a few seconds and the battery light came on and power steering stopped working as I was pulling up to the gas pump in wet pre snow conditions. This has never happened before and is it just a Fluke?
Old 12-09-2009 | 01:59 AM
Default JUst A Fluke Maybe !
Hi Chris..if it does it again, it's no fluke..Check your Belt Tensioner..
Attached Thumbnails 2003 Accord EX accessory belt slipping why-hanginfrom-my-mirror.gif
Old 12-09-2009 | 03:46 AM
kris_loehr's Avatar
Any guess where in the dealership parts System\Component menu it is listed?
Old 12-09-2009 | 08:10 AM
It's called "engine mounting bracket". What were they smoking when they made up that name??
Old 12-09-2009 | 05:47 PM
kris_loehr's Avatar
I appreciate the help and ordered the Belt Tensioner from the local dealer as I can’t take a chance on it happening when my wife is driving to work.
Old 12-09-2009 | 06:15 PM
finch13's Avatar
I would also check the belt and replace if necessary. What's the rule of thumb? More than 3 cracks in a 1" section, replace? Better safe than sorry and belts are relatively cheap.
Old 12-09-2009 | 07:10 PM
kris_loehr's Avatar
Belt is an OEM honda with 3,000 miles but I will look it over also.
Old 12-10-2009 | 07:56 AM
There's a little pointer or something cast into the tensioner around where it pivots. If the pointer is outside the range of where it belongs, that means the belt is stretched.
Got an oil leak anywhere that's getting on the belt?
Maybe the spring inside the tensioner has gone weak - you can compare old vs. new when you get the new one.
And... check for all the OTHER pulleys driven by this belt. If the idler or maybe the waterpump has developed way too much drag, the alternator is where you'll notice the consequences.
Old 12-10-2009 | 06:29 PM
kris_loehr's Avatar
The range on the tensioner looks like a sideways L which is the max? I have no oil leaks but the tensioner looks pretty bad with rust and grooves worn into the machined part for the belt to ride on.
Old 12-14-2009 | 09:38 AM
IIRC there's a little mark on the moving part that lines up along that "L". When that little mark moves outside of the "L", then the belt has stretched too much.
There may be a picture of the mark somewhere in the owners manual.
Rust & grooves sound like a good excuse to buy a new tensioner. The belt on my 2003 never stretched, but it got tiny little surface cracks - so I figured the rubber was getting hard & slippery. And the tensioner pulley bearing got loose & wobbly. Never had to replace the tensioner arm tho...
