2003 Accord OBD connector
Old 03-20-2011 | 01:41 PM
aguanile21's Avatar
Default 2003 Accord OBD connector
My 2003 Accord failed inspection in NJ do to OBD connector. What or where can I locate in the car?
Old 03-20-2011 | 02:42 PM
Old Honda Dude's Avatar
Default OBD Connector
Most all honda cars have the location of OBD 2 connector under the base of the steering wheel. just put your head under steering wheel and look up just behind the steering wheel. white sticker with black type.
Old 03-20-2011 | 02:43 PM
its bellow the steering wheel on left side above foot well just below trim pannel
Old 03-20-2011 | 03:59 PM
Have your system checked by another scanner to see if it works. I've heard of faulty OBD2 connector on inspection service scanner failing and causing them to suspect car instead of their equipment.
Old 03-21-2011 | 03:43 PM
aguanile21's Avatar
Thanks. I will do this.
Old 03-21-2011 | 03:44 PM
aguanile21's Avatar
I will check this out.
Thanks.
Old 03-21-2011 | 03:45 PM
aguanile21's Avatar
Great!!!!!! I will check it out........
Old 03-21-2011 | 11:07 PM
Yes let us know what you found out..I moved this to this forum...
Old 02-19-2021 | 06:07 PM
jemyers08's Avatar
I drive a 2004 Honda Accord with the good ol' 4 cylinder engine and love it. It's almost broken in. I experienced the same problem with a loose
ODB2 connector thanks to an annual inspector pushing hard enough to break it loose. A little silicone calk along the sides fixed it, and made it usable.
God bless the USA and hope you all stay healthy,
Jim US Army (retired)
Balsabill
10-15-2012 10:11 AM
tashier
02-28-2012 04:57 PM
jrgray86
09-12-2009 03:06 PM
jipmpizzle
06-20-2008 05:09 PM
bigracefan18
07-03-2006 09:55 PM
Quick Reply: 2003 Accord OBD connector
