2003 Accord Winshield Wiper Flopping
Hi,
My 2003 Accord driver-side windshield wiper arm is flopping around when turned on.
On the driver side, I can easily rotate the arm around the screwed on connection point (on the firewall). There is a hand-tighenable cap nut that is on and was loose when I first found it...so tightened it as much as possible, but no fix...must be a round slot that the arm locks into?
Thoughts on what might be the issue?
I tried to take off the arm (by removing the hand-tightened cap nut) , but doesn't want to come off. How do I get this off?
Thanks!!!
Andy
Thanks!!!
Andy
After you remove the nut, push on the arm between the nut and the pivot point. This is usually all it takes to loosen it. You might have to lift the wiper into the "clean the windshield" position cuz sometimes the spring on the arm kinda wedges the arm onto the shaft.
outlaw423
12-31-2011 07:21 PM
