2003 automatic power door locks wont lock
Old 08-13-2012 | 08:49 AM
98013HWR's Avatar
Do they lock with the key in the door.
Old 08-13-2012 | 08:42 PM
tshannoz's Avatar
No, only the drivers door will lock when I use the key. Before this happened, all the doors would lock when I manually locked the drivers door.
Also, when all the doors are closed, the overhead dome light remains on. Forgot to add this detail in my first post.
Old 08-14-2012 | 06:29 PM
Does the little light on the door stay on as well?
And please add you car info to you signature line.
Old 08-15-2012 | 08:23 PM
tshannoz's Avatar
Intersting. The little light on the door actually turns off. Only the dome light stays on when all the doors are closed. Is there a way to find the source of this? Maybe a short that makes the car think the doors aren't closed?
Old 08-16-2012 | 07:49 AM
There's a timer, right? So the door light turns off immediately but the dome light stays on for what, 45 seconds or something? Sounds like the switch is OK but the timer isn't.
Old 08-16-2012 | 07:23 PM
tshannoz's Avatar
I'll time it, but I think the dome light stays on indefinitely now. It used to just fade to off when the doors were closed. What sensor determines if a door is open or closed? I'm thinking that since the dome light is staying on that the car thinks a door is still open and maybe this is why it won't lock. Does this seem plausible?
  #17
Old 08-17-2012 | 07:07 AM
That seems plausible, but the same "sensor" should control both the dome light and the small lamp on the door itself. It's a small button covered with a rubber boot, in the door-jamb.
Check also the switch on the dome light itself - is it turned on?
  #18
Old 08-17-2012 | 08:05 AM
tshannoz's Avatar
The dome light has a Door setting and and Off setting. When switched to Door, the light stays indefinitely when all doors are closed. And the doors don't lock.
Also, I found this last night. Does anyone know about the MICU? This is a Honda Tech Bulletin and it sounds like maybe my MICU may be an issue. Is this something I can fix myself or will I need to bring it to the dealership?
http://www.motobild.com/wp-content/u...9190277463.png
  #19
Old 08-17-2012 | 11:19 AM
Yeah, that multiplexer controls things like locks & lights, so that's a good possibility.
Without having the HDS (Honda's proprietary scan-tool) I think there is a procedure for re-booting the multiplexers. It's something very strange like set the wipers switch a certain way then turn something else on. Search for "reset multiplex" both here (General Tech) and in the DIY sections. I never had to do that while I owned a 2003, so I don't know the details.
  #20
Old 08-17-2012 | 03:08 PM
tshannoz's Avatar
Yeah, I'm not to enthusiastic about going to the dealership for an HDS scan. Thanks for the multiplex reset idea too. I'll see what I can find.
Quick Reply: 2003 automatic power door locks wont lock
