2003 Honda Accord 38k Rough Idle
Hello,
I own a 2003 Honda Accord 4-cyc,auto trans with 38k miles. I've notice my car idles rough when stopped in drive. I'll be at a stop light and the engine idles rough. The tac is around 800 rpms. When I step on the gas to go, the rough idle goes away. When I put it in park, the rough idle goes away????
Does anyone know what this problem could be???
Thanks,
Sheryl S.
Thanks,
Sheryl S.
Rough like vibrations? Or does it surge faster & slower instead of a steady RPM?
If it vibrates, maybe it's the vacuum-operated front engine mount. Wanna check it out yourself? It's front & center, labeled #9 in the picture below.
There's a vacuum line #16, #17, & it somehow connects over to a solenoid valve in the box labeled E-3. (My 2003 was a manual tranny, didn't have the vacuum-operated mount, so I don't know exactly where that solenoid valve is located.)
Get the car warmed up, have someone in the car, with the engine running. Put it in Drive or Reverse & hold the brake. Unplug the electrical connection to that solenoid valve. That SHOULD make it real rough. If not, then the mount isn't working properly. Let us know what happens, & then someone can figure out what to check next.
HatchJunki
03-09-2013 09:23 AM
