2004 Accord 4cy Engine Vibration
Old 01-30-2012 | 08:23 PM
ChristieTennessee's Avatar
Default 2004 Accord 4cy Engine Vibration
2004 Honda Accord EX
4cy
Automatic
Had a slow vibration between 50-60 mph (kind of a whomping sound).
1)Recently had four new tires, allignment, but problem persisted.
2)Changed all three motor mounts with after market parts. Now, there is a new bad vibration inside the cabin at 900 rpm. Engine runs smooth.
3)Checked the front vacumm mount with no vacumm and full vacumm, but no change in vibration. Engine and Tranny are not touching anything to cause the problem.
Could it be the transmission torque converter? Or does anyone have any other suggestions? Would LOVE to hear any possible solutions. We have had 3 mechanics racking their brains over this issue.
Old 01-31-2012 | 08:19 AM
#1 might be a wheel bearing?? At least check to rule them out.
#2 Not sure but I kinda remember there's a particular sequence of which mounts, & which bolts to tighten in which order. If you simply bolt em all up in random order the mounts end up sharing the load incorrectly.
When you checked the front engine mount (vacuum vs. not), was the transmission in gear with someone holding the brake pedal?
Old 03-07-2012 | 06:23 PM
gForce's Avatar
Lightbulb
Vibration at certain speed is the axle if tires are balanced and alignment are ok.
Lance Shaddix
07-11-2012 02:33 PM
jb08177
05-02-2011 10:06 PM
mike929
06-09-2010 05:10 PM
Daveyjones
06-04-2007 12:43 AM
kwp1229
09-22-2005 05:57 PM
