2004 Accord LX Heater Problems
I just turned on the heater and it blows cold air on all the different controls except when i put it on vent and it blows hot air out passenger side but still cold on driver side. Any suggestions on where to start to fix issue?
Could be an issue with your air blend doors or a possible clogged heater core.
Start with the simple test. Go to the common DIY thread in the gen tech help forum. There is a link for HVAC codes on your car. Get the codes and post any codes you get on here.
You should have 3 actuators. Check your air mix door actuator and your blend door actuators. You're going to have to have someone help you by changing the modes and temps while you look. 2 on the right 1 on the left.
