2004 Air Conditioner blowing hot air
Have a 2004 accord ex that started blowing hot air out intermittently. When it is blowing cold, it will have a 'funny' smell (like crayons) and then start blowing hot air. It blows hot out all of the vents. Currently, it blows hot more often than cold. Could this be as simple as needing refrigerant?
Thanks in advance,
Scott
Thanks in advance,
Scott
It could be, but you need to measure high & low pressures to be sure.
Besides, that leaves the question of where is the leak. You (or your mechanic) can use a dye to find the leak. If you don't fix it, it'll just leak out again.
LouieChuckyMerry
06-01-2018 07:35 PM
BHoward711
04-12-2010 08:57 PM
jeremiah6120
04-16-2006 03:32 AM
