2004 Coupe lifting points
RE: 2004 Coupe lifting points
welcome to HAF......
if you look under the car, behind the frt wheel and in frt of the rear wheel you will see reinforced higher spots.. that's where you jack the car up from.....
Do you live in tucson ?? or since it says Tucson X you used to live there ?
Thanks for the reply - after posting this I looked under the car and saw the large arrow molded into the plastic underpanel pointing to a reinforced area of the front crossmember, so I used that and the rear tie down ( like all the other Acuras and Hondas I have worked on) to lift the car with the floorjack and put the jackstands under the areas you mentioned. Just today my manuals arrived from Helm Inc. and confirmed the procedure - and yes I do live in Tucson. Check out the avatar - tucsonsx is tucson and nsx combined into one word.
