2004 Honda Accord EX Timing Belt/Water Pump Replacement
Old 05-15-2009 | 03:40 PM
mark95
Default 2004 Honda Accord EX Timing Belt/Water Pump Replacement
Hello All,
I did a timing belt/waterpump replacement on a 1995 Lexus LS400 about 2 years ago. The crankshaft bolt had 180 ft-lbs of torque. One solution to remove the bolt was to secure the bolt with a breaker bar & socket and quickly turn on/off the ignition switch. This worked like a charm.
Has anyone tried this approach on a 2004 V6 Honda Accord EX?
Mark
Old 05-18-2009 | 12:47 PM
I've heard of that on other cars; should be OK with the V-6 or the 2003+ K-series.
Make sure you support the car. It would not be good if this knocks it down off the jackstands.
Anyone with an F-series 4-cylinder, that engine spins in the wrong direction. Doing this would tighten the crank pulley bolt.
zacharyzoosh
06-30-2013 01:42 AM
piggylover1985
05-27-2011 06:28 PM
hardlymoving
09-17-2010 05:38 PM
pimpp1184
11-05-2009 10:55 AM
carbonatd
01-19-2009 01:14 PM
