2004 Misfiring when idle. MAS
Old 05-24-2018 | 08:56 AM
Frank2004accord's Avatar
Default 2004 Misfiring when idle. MAS
Hello, My 2004 Accord is almost stalling when stopped. Originally, there were no error codes, even though it was having slight intermittent misfires. I cleaned the mass air-flow sensor with the proper cleaner, but I think I did not let it dry enough before putting it back.
When I put it back, the misfires got worse, and all cylinders reported misfires, in addition to codes about Mass or Volume AirFlow Low Input, and Intake AirTemp Circuit High Input.
I changed the air filter and cleaned the housing, and cleaned the MAS again, and it got a little better, but still same problems.
I ordered a new non OEM MAS and installed it, but problem persists, and now it comes even closer to stalling, so I put the old MAS back.
Engine will do a pretty big misfire on a strong acceleration, so I've been avoiding that.
Similar thing happened about a year ago, and the problem was a loose spark plug. All plugs are tight.
Appreciate any guidance with this problem.
These are the current codes:
P0102 Mass or Volume AirFlow Low Input
P0113 Intake AirTemp Circuit High Input
P0300 Random Misfire
P0301 No. 1 Cylinder Misfire
P0302 No. 2 Cylinder Misfire
P0303 No. 3 Cylinder Misfire
P0304 No. 4 Cylinder Misfire
Last edited by Frank2004accord; 05-27-2018 at 01:56 PM. Reason: updated verified codes -bold text
Old 05-27-2018 | 01:51 PM
Both P0102 and P0113 are circuit problems and can be sensor, wiring, connector or ECM circuit fault.
Diagnostics w/ multimeter are necessary. Are you up to such diagnostics?
Old 05-27-2018 | 01:54 PM
Default Yes
I have a multi meter and I am willing to check things. Thank you for your reply.
Old 05-28-2018 | 10:12 AM
Attached are diagnostics.
You don't have to slavishly follow diagnostic, but rather determine if fault is 1) sensor, 2) wiring or connector, 3) If sensor, connectors, and wiring are absolutely good, then by default the ECM is fault.
File Type: pdf
File Type: pdf
Old 06-03-2018 | 11:23 AM
I have a SULEV engine, so I guess that means there is no separate IAT sensor, and only the MAF sensor?
#18 fuse is good. Trying to test more today.
Old 06-03-2018 | 11:44 AM
The SULEV had a MAF/IAT sensor. It is a combined sensor.
Old 06-03-2018 | 12:05 PM
Thanks.
So, I'm getting no voltage with the ignition in II, disconnected MAF, pin 5 to chassis ground. Says to repair open wire between #18 ACG 15A fuse and MAF sensor.
Sounds like a challenge.
Old 06-03-2018 | 12:51 PM
Did you check under-dash Fuse No. 18 and also to see if there is power on both sides of the fuse with the ignition switched to ON?
Old 06-03-2018 | 01:53 PM
Default voltage
With ignition in II, fuse #18 reads 12V on both sides.
Confirmed again that no voltage is present at pin 5 of unplugged MAF/IAT harness with ignition in II.
Is there supposed to be 12v there?
Old 06-03-2018 | 02:39 PM
Yes, there is suppose to be battery power at terminal pin number 5, Blk/Yel wire with the ignition switch in the ON or START positions.
The Blk/Yel wire runs from the back of the under-dash fuse/relay box through a couple of junction connectors and connector to the MAF/IAT sensor.
Junction Connectors are used to split/distribute power and/or ground from source(s) to various components. Terminals grouped together are connected by the same bus bar.
C556 is a junction connector located inside the cabin, under-dash area it initially goes through.
Then the Blk/Yel wire goes through terminal no. 5 in Connector C201. Take a visual look at the wiring at Connector C201, you can also test for power at terminal no. 5 here.
Then is run through a junction connector, C102 before it reaches the MAF/IAT sensor connector:
