2005 Accord V6 Check Engine Light Flash
Old 12-23-2006 | 11:23 PM
rmistry7's Avatar
Default 2005 Accord V6 Check Engine Light Flash
Recently I changed the headlight bulbs on my 2005 Accord EX V6 Auto sedan to the Sylvania Silverstarr brand. They sure make a big difference compared to OEM. Anyways, in order to change the driver side bulb I had to disconnect and remove the battery so I can get at the bulb. Since then, I noticed that anytime I accelarate hard aka RPMs exceed 5k, the check engine light flashes for a while then goes away. It has happened twice so far. I am aware that when you disconnect the battery, the car's computer takes time to reset. Is this normal, or do I need to take it to a mechanic to find out if there is a malfunction? Otherwise, the car runs great. If I dont accelerate like a maniac, the check engine light does not come at all. Any thoughts anyone?
Thanks
Old 12-24-2006 | 05:17 AM
YeuEmMaiMai's Avatar
Default RE: 2005 Accord V6 Check Engine Light Flash
ramdom multiple misfire would be my very first guess. check all of your wiring....
Old 12-24-2006 | 03:54 PM
deserthonda's Avatar
if less than 36k miles, car is still under warranty, take it to the local Honda dealer and have them chk it out
Old 12-24-2006 | 04:46 PM
rmistry7's Avatar
Car has over 43k on it, but I do have a extended Honda Care Warranty till 100K. I will have it checked out at the local dealer.
Thanks
Old 01-17-2007 | 01:28 AM
rmistry7's Avatar
I finally got around to taking the Accord to the dealer. I have warranty that covers me. The dealer found fault code P0301 "Small carbon crack on the #1 sparl plug causing a misfire". Dealer changed the plug, picked car, and guess what??? Check engine light on again if I were to drive it hard. Taking it back tom. Anyone else have similar problem like this?
Old 01-18-2007 | 06:25 PM
vwl1980's Avatar
sorry never seen that one.i have an 04 ex coupe,and ive had my check engine light come on a few times.its been a real pain in the neck
Old 01-18-2007 | 10:56 PM
hondadude's Avatar
ORIGINAL: YeuEmMaiMai
Right; it could be a wire in the trunk lid.
[sm=icon_rofl.gif]
Old 01-26-2007 | 09:13 PM
rmistry7's Avatar
I took it back. The technician pulled the coil for number 1 cylinder and put it on number 5 cylinder. Cylinder 5 came up in check engine light. Dealer replaced coil and car runs fine. Problem solved at zero out of pocket for me.
remacts
09-19-2012 07:37 PM
suenjbo
08-30-2012 11:47 AM
insane831
11-04-2009 11:41 AM
dan_o_89_rs
10-02-2007 09:05 AM
