2005 accord wont start
DTC P0498: EVAP Canister Vent Shut Valve Circuit Low Voltage
DTC P0135: A/F Sensor (Sensor 1) Heater Circuit Malfunction
First check under-dash Fuse No. 4 (15A) and No. 23 (7.5A). Both these fuses are related to the A/F sensor relay (located in the under-dash fuse/relay box). The A/F sensor relay provides power to both the EVAP Canister Vent Shut Valve and the heater circuit of the A/F sensor.
If the fuses are good and power is at both sides of the fuses, you can swap the A/F sensor relay with the one of the relays right next to it (as they should be the same type) to see if things change. The A/F sensor relay is located in the under-dash fuse/relay box, at the bottom row with 4 relays, from left to right, it is the 3rd relay.
If no change, wiring may be checked next.
okay guys heres what I did I found the ecm/pcm and unplugged every thing and then plugged them back in and now the car starts and runs like it did the only thing now is the check engine light wont go off we tried to reset it but it wont go away but hey the car is running
gasface11
07-11-2012 12:33 PM
smoletx
02-20-2008 10:13 AM
