2006 2.4 L, hit curb, uneven tire wear on both sides of tire
Slid on snow and hit a curb in parking lot entrance (low speed but hit with a BAM). Now front left tire wears bad on inside and outside. Drives straight without vibration steering wheel shake or excessive pulling. Makes a low thrumming noise, not quite the gravelly grinding you can feel with a bad bearing or hub. I pulled the wheel assembly off and the bearing turns even and smooth. I wanted to replace the hub & bearing before an alignment to eliminate that as an issue. Now I am thinking could it be a lower ball joint, bent lower control arm or tie rod end. Any suggestions before I start pounding out the bearing and hub? The seals on all the bushings are good. I don’t have an air hammer to get out or in a ball joint.
So the thrumming sound was my tire wobbling back and forth. The lower ball joint was shot, but the rubber was not broken & that caused wear on the outside edges of the tire. The wheel must still be true as the steering wheel never shook. I got it all apart from the car, but decided to take it to my mechanic so he could press ball joint out and a new one back in. What I learned is to get your car checked right after hitting anything! Not only did I have to drive out the ABS wheel speed sensor ($75 from Honda) that was stuck, now I will need (2) new tires for the front. Thanks for the help.
On my own Accord, I replaced hub bearings and ball joints, as they had 234K on them, and the hub bearings were loud. The ball joints were originals too, as they didn't have a snap ring on them like the replacements had.
ryanw2427
07-05-2015 07:54 PM
ranma21
10-21-2008 12:16 AM
