2006 Accord 2.4 i-VTEC throttle actuator motor wiring
Old 11-04-2013 | 12:25 PM
Loren32's Avatar
Default 2006 Accord 2.4 i-VTEC throttle actuator motor wiring
I have a 2006 Honda Accord with 2.4 i-VTEC motor. Had to change a bad starter. When I did, some of the wires on the throttle actuator motor(on the back side of throttle body) came off. There are 6 wires: 2 blue, 2 green, 1 red/blue, 1 red/black. Can anyone help me with the proper positions for these wires? The car will start and idle but will not accelerate at all.
Old 11-04-2013 | 05:50 PM
If you don't mind....I've move this to General Tech where I think you'll get better answers.
Old 11-04-2013 | 06:07 PM
TP Sensor/Throttle Actuator 6-P Black connector:
  • 1 Red/Blk (TPS1)
  • 2 Blu (VCC)
  • 3 Red/Blu (TPS2)
  • 4 Grn (SG)
  • 5 Grn (M (-))
  • 6 Blu (M (+))
Old 11-04-2013 | 06:13 PM
See....I figured rebdbull would be all over this. I'm still trying to read everything else and there he goes.
Old 11-05-2013 | 01:35 PM
Loren32's Avatar
Thank you very much for your help poorman and redbull! That's the ticket. I usually take pictures before hand just in case and I didn't this time.
Old 01-09-2019 | 02:46 PM
Donn Tattoozbysqueak Harris's Avatar
Default can i reconnect these wires,,,HELP!!!
  • 1 Red/Blk (TPS1)
  • 2 Blu (VCC)
  • 3 Red/Blu (TPS2)
  • 4 Grn (SG)
  • 5 Grn (M (-))
  • 6 Blu (M (+))
Old 01-09-2019 | 02:50 PM
2006 accord 24.l i-vtech...car idles but wont accelerate at all after wires on throttle actuator came off,,can i replace?
Old 01-09-2019 | 02:51 PM
Hey i did this same thing is there a way to fix it?
Old 12-28-2022 | 08:19 PM
spencerwaters07@gmail.com's Avatar
Default 2green 2 blue
In the below blue and green are listed twice (because there are in fact 2 blue and two green wires. How do I know which blue is #2 vs. #6 ? How do I know which green is #4 vs #5? Does it matter?
  • 1 Red/Blk (TPS1)
  • 2 Blu (VCC)
  • 3 Red/Blu (TPS2)
  • 4 Grn (SG)
  • 5 Grn (M (-))
  • 6 Blu (M (+))
Old 04-29-2023 | 08:05 AM
Terio22's Avatar
Default Throttle body wiring
New here. Please help, I had to replace the throttle body pigtail on my 06 accord 2.4 four door. I stupidly did not label the wires to easily reconnect. I had not noticed that were two blue and green wires. Can someone please help me In figuring out how to find out witch blue goes to blue and green to green please. Thank you.
Quick Reply: 2006 Accord 2.4 i-VTEC throttle actuator motor wiring
