2006 Accord 2.4 i-VTEC throttle actuator motor wiring
Old 04-29-2023 | 08:17 AM
Terio22's Avatar
Default Same problem
Just wondering if anyone ever figured out this question. Which green wire is witch and blue as well.
Old 04-29-2023 | 09:04 AM
Yes, it matters where each blue and green wires go. To determine the proper wires, you can do a continuity test on the green and blue wires. It will require testing equipment like a multimeter/ohmmeter.
To test for continuity, set to either the "ohms" or the setting it will beep when you hold the two leads together.
  • If your meter beeps, it means you have continuity.
  • If it is on ohms scale, you will have continuity when it reads close to 0 ohms.
  • If it doesn't beep , shows OL (open line) or a 1 (infinity ohms); it means you don't have continuity.
The other wire ends goes all the way to the throttle actuator control module (located under the passenger side dash). You would disconnect the harness connector there and check continuity between the various blue and green wires at the throttle body. The green wire from the under dash connector at terminal no. 8 and blue wire at terminal no. 1 should have continuity to the green wire at the throttle body at terminal no. 5 and the blue wire to terminal no. 6. Those are for the motor.
Old 04-29-2023 | 10:04 AM
Terio22's Avatar
Thank you redbull. I’ll take care of that asap.
Old 09-22-2024 | 09:29 PM
Twizzle's Avatar
Same thing happened to me. The car idles high and jerks when changing gears.
I’m not sure how these harnesses work. Can I just plug them back in or should I buy a new harness and rewire/solder?
thanks
Maria Penguini
07-15-2014 10:39 PM
Doublel
03-11-2013 07:57 AM
larrypac99
12-18-2011 03:10 PM
taj693
03-12-2011 10:38 AM
Al_S
06-26-2010 08:17 PM
Quick Reply: 2006 Accord 2.4 i-VTEC throttle actuator motor wiring
