2006 Accord Driver side window broke
Old 04-03-2013 | 12:07 PM
frt2599's Avatar
Default 2006 Accord Driver side window broke
Hi..
I have an 06 Accord that the driver side window has stopped working. For the past year when I would use the one touch up, it would go about 1/4 of the way up and go back down. If I held the switch up it would go all the way back up so I just dealt with it. Yesterday it stopped working (up or down) all together. Before I replace the regulator/motor, is it possible the window switch itself is bad? And if so how can I test this. Thanks
Old 04-03-2013 | 07:03 PM
Could be the switch.
Are the other windows working?
Is this a two or four door?
Is the #27 under dash fuse (20 amp) good?
Old 04-04-2013 | 11:14 AM
frt2599's Avatar
Thanks for the reply....
Yes, all other windows are working
Accord is a four door
Checked #27 fuse and it's good
Luckly I have a friend that has a 06 Accord. I am going to take his switch out and try on mine. So that will tell me.
Found these on the internet if anyone needs them
http://www.dormanproducts.com/Digita...741-306_IS.pdf
jza240sx
04-30-2013 05:14 PM
kodoo
02-03-2012 07:54 PM
g22cd5
11-05-2010 02:29 AM
mngantung
08-05-2006 03:22 PM
