2006 Accord LX electrical help needed
Old 09-14-2020, 05:40 PM
Jesse Torres's Avatar
Thanks so much for helping me out Redbull-1
i checked these out and terminals 10 grn/wht and 15 wht/red are not hot with key off, or not even with key on.
and terminal no 20 is hot with the key on.
I also discovered of fuses 24-25-26 and 27 p/w fuses, 27 is the only one that’s hot, other 3 are not hot and not blown
Old 09-14-2020, 05:43 PM
I also discovered of the underhood fuses, these are not hot and also not blown either
Old 09-14-2020, 06:27 PM
Under-dash Fuse No. 24, 25, and 26 only get power if the driver's door master switch sends a ground signal to the power window relay.
If the door locks and windows worked before removing the Karr system, was there some wire removed at the under-dash fuse box going to the door jamb?
Power from the under-dash fuse box fuse no. 7 (10A) and 27 (20A) goes through wires at the Connector C632 at the door jamb. You might want to examine the wiring running from the fuse box, through the door jamb, to the master switch.
Old 09-14-2020, 06:39 PM
Those fuses are related to the headlights. The headlight switch has to be turned on for high beam or low beam before power goes through the headlight relays to those fuses.
Old 09-14-2020, 06:47 PM
Check the #23 P/W 50A fuse in the engine bay fuse box.
Old 09-14-2020, 07:04 PM
Ok, I’ll check this out, thanks so much for your help.
  #17
Old 09-14-2020, 08:22 PM
Do I test this with a volt meter correct, not a test light
  #18
Old 09-14-2020, 08:32 PM
I’m sorry guys, all alarm wires were put in with a single wire quick splice connector but I forgot about this one. It has 2 green and 2 blue wires that go up behind the fuse box. They were all crimped together on one side of the connector and on the other side was a single brown wire that went to the KARR alarm. Should I just snip and tape the 4 wires at the connector for now, or should I wait till this weekend when I can tear it apart to see what’s going on behind the fuse block. Thanks for all of y’all’s help.
  #19
Old 09-14-2020, 09:25 PM
I recommend waiting and trying to figure out what was done to the wires before messing with them. You may want to google the installation instructions for your alarm system to see what wires were cut to revert back to the factory setup.
  #20
Old 09-15-2020, 06:49 AM
Seanjordan20's Avatar
I also suggest check the wire behind the box. It was just too much of a coincidence that everything stopped working once you removed the alarm meaning there was still a wiring issue. What are those blue quick connects in the pic for. You have a lot going on under the dash.
Quick Reply: 2006 Accord LX electrical help needed
