2006 Accord Power outlets
Hell everyone,
I am new to this forum. have looked here in the past for answers to my accord problems. This is my first post , hope someone can help. On my 2006 Accord, none of my power outlets work. everything else works. All of the fuses are ok as well. Could this be a relay problem? if so, which one is the accessory outlet relay?
thanks in advance,
gary
thanks in advance,
gary
It could be a relay.
This is based on my 05 TSX manual (which should be very similar to your accord).
The relay is in the fuse box under the hood. If there is an identical relay, switch them to see if the power sockets work and the other component doesn't work. If you can not find another relay, or your power sockets do not work, then you can try some tests with a volt meter on the relay socket and/or the relay.
There seems to be two fuses in the under hood fuse box that could cause the accessory power sockets not to work. Just wanted to mention this incase you only looked in the fuse box under the driver's side of the dash.
I would probably buy the 03-07 shop manual. I got one for my 05 TSX Ebay from the seller called automanualsource for $22. I could download it almost immediately after I paid. If you plan to do you own work, this is essential, and will pay for itself when you repair one item on your car.
WHATABURGER
08-28-2008 02:32 PM
