2006 Hybrid
There are four screws to remove for access, one of which is buried under two cable that are attached the filter box and the adjacent fuse/relay box that is less than a inch away, and the cables are very short. If I cut the cable retainers I wouldn't be able to replace them.
Not a good maintainability design.
Anyone have a V6 hybrid that has done this? I'm not sure a non hybrid is the same.
I don't have a hybrid, but wiring harnesses normally have clips that can be opened or disconnected to allow you to flex the harness away.
On the 2007 Civics I normally unplug the wire from the MAF sensor just to make it easier.
2006 Accord air filter
Well, I got it replaced. It wasn't easy. Three cables limit lifting the cover just enough to remove the filter. Force was necessary. Had to cut two cable retainers to get the fredom to lift the filter cover.
Thanks all for the help.
Ciao
Ciao
Gas Mileage reducion
My 2006 Accord hybrid has shown a markid reduction in gas mileage from a constant 30 in general driving to 24 mpg. It has about 63,000 miles and runs great. These are indicated mpg on the instrument panel.
Any thoughts?
Any thoughts?
