2007 Accord Won't Start
This will get confusing...I've merged the two threads together and moved it to General Tech - better place than the new member area....BTW, welcome to HAF.
What is the starter doing? Is the starter spinning the engine, or when you turn the key to start - nothing happens?
Yea, if you have a remote or alarm I would try re-setting them as they might have "tripped" when removing or re-connecting the battery.
When you turn the key to the "on" position, do you hear the fuel pump prime for ~3 seconds?
Check the battery connections again. Disconnect and reinstall them to see if it makes a difference.
If it still doesn't start, pay attention to what the instrument panel Immobilizer indicator does when you turn the ignition with the key; and report back what it shows.
Sheri6889
06-17-2015 09:19 AM
Lunalobowolf
10-26-2012 10:33 PM
