2007 Honda Accord A/C & Heater quit working
Old 08-15-2014 | 02:54 PM
Turtlehead's Avatar
When the fan stops working try taking your fist and whack the blower motor. If it starts back up then it is usually a bad spot in the motor which would then need replacement. You can also try removing the motor and hot wire it to see if it works fine. If it does not then replace, if it does reinstall and check for loose connections.
Old 08-15-2014 | 03:38 PM
Blower fan motor can be easily tested in car by using a jumper wire, see thread:
https://www.hondaaccordforum.com/for...accords-59744/
Tony1M
11-06-2023 08:29 PM
BSims66173
11-09-2012 11:52 AM
Driver 1
05-25-2011 11:33 PM
bglovept
08-25-2010 07:50 PM
fuctcivic
11-17-2006 03:34 AM
Quick Reply: 2007 Honda Accord A/C & Heater quit working
