2007 Honda Accord low air flow ???
I have a 2007 Honda Accord V6 occasionally my air condition blows with low air flow, its cold but the air flow is very low even when I turn on full blast.
And it will come back working properly with full high flow cold air, any suggestions ??
Also, I have the navigation with the touch screen.
But I can hear the blower motor going full blast when on high, its just when I put my hand over the vent it some times comes the air flow is low like something is blocking the air flow, and this happens occasionally.
Put the air on only the center vents to see if it blows like it's suppose to. I have an 07 and I don't hear my blower motor blowing. You want can always drop the blower motors to see if you have leaves or debris in it other that than it's the resistor
The mode and recirculation door actuators will both be on the passenger side between the case sections.
The temp blend actuator (if single zone; or, driver blend if dual zone) is on the far left side of the housing - should be visible just above the gas pedal, or you may need to remove the trim panel first.
If you have dual zone temp control, then the passenger blend actuator will also be in the gap between those sections.
Removing the glove box (like you would to change the cabin filter) should allow you to at least see the mode and recirculation actuators. With the key on, select each mode, recirculation, or temp blend and watch for movement from the actuators (typically the shaft of the actuators are visible from the back side) to determine which one is responsible for which function. If you see one that isn’t moving, either the actuator is bad or there’s a problem that’s keeping the door from moving.
