2008 Brake problems
Old 05-31-2010, 11:18 PM
Originally Posted by EXV6NIGHTHAWK
I wonder if that dealership has seen, and done this. It seems some callipers were installed with the pins wrong. They also added the little V clip to push the pads away from the rotor.
Could you please elaborate? Thanks.
Old 06-01-2010, 04:00 AM
Default 2008 Brake problems
I have 18" alloys on the car 07 SE and the brake discs appear to be quite badly corroded along the outer 1cm depth around the circumference of the front and rear discs. Its almost as if the pad doesnt make contact with the outer 1cm of the disc. Is this normal or are 1 the discs fitted the wrong size or 2 the pads are the wrong size? By the way, to whom the {url=http://www.SPAM.ua/catalog_rub3.htm}biotualet{/url} is necessary, come I recommend {url=http://www.SPAM.ua/catalog_rub3.htm}biotualet{/url}.
Old 06-02-2010, 08:00 AM
Mikebike125's Avatar
After about 4 days of driving, I think the pedal is still soft so I am going to compare it with a new system and see what the dealer says. Right now the pedal is softer than on my 2001 Odyssey and I don't think it should be. Just seems like the pedal moves too far compared to other cars.
Old 06-04-2010, 05:28 PM
Compared it today and it feels like a new one. Looks like it is finally fixed.
Kathleen
08-02-2011 08:16 PM
redman4ever
01-31-2011 04:23 PM
rtprthd
01-26-2011 06:24 PM
thunderman
02-20-2010 09:43 AM
KimberlyC
04-16-2006 11:51 AM
Quick Reply: 2008 Brake problems
