2009 accord 6spd. whine noise
I have just bought a 2008 Honda Euro 6 speed manual and just as you said
hi there I have just bought a 2008 Honda euro and I have noticed the noise too. I changed the tyres but it's still there. Sounds like the same thing you have. Not sure what it is
thanks for the replies. Moderator, yes noises are hard to diagnose in a forum. but if you read my text carefully you would understand this has nothing to do with tires or brakes. I didnt mention I have 5,000 miles on the vehicle and this has been doing this since the beginning with no increase or decrease in the sound.
Again, you must have a near silent cabin. when going 55+ and you give it a steady gas you'll hear it, then just let off the gas enough that the sound goes away and then give it gas again and the sound re-appears. Make sure you don't floor it or give it too much on the pedal. Just enough pressure on the pedal and just enough off till you're not giving her any gas.
Personally I think that its the nature of the beast and thats what is bothering me. A $30k car, especially a Honda, with a reputation for quality et al has this in my opinion, FAULT. Thank goodness its not that noticable and I will admit, noises bug me more than most. Hopefully others with the 6spd will chime in. In the meantime I'll be calling Honda in CA. regards...
If I remember right, there's a TSB for 3rd gear on 6 speed transmissions. Don't know if it would apply to what you're hearing, but it is for 2007 thru 2009 Hondas with 6 speed transmissions. Might be worth checking into.
I have attached a PDF of my invoice with all the parts that were used. Hope it helps...
airtrafficone
07-06-2010 07:55 AM
