2013 Accord front passenger window will lower but not raise
Old 03-27-2015 | 03:10 PM
Cheapshot's Avatar
Default 2013 Accord front passenger window will lower but not raise
Hello all
I'm having a problem with my 2013 Honda Accord LX. My passenger side front window goes down normally using any switch (either driver's side or passenger's side) but will not come back up. I've already swapped the fuses, so that's not the problem. All other windows work normally by using either the switch on the window itself, or the master switch on the driver's seat. Both the driver's seat and front passenger's switches cause the passenger side window to lower, but it will not come back up using any switch.
Anyone have any ideas?
Old 03-27-2015 | 03:36 PM
If Fuse B33 is okay, then possible issue with power window regulator. Kind of unusual for window regulator to be faulty this soon; but, things like this sometimes happens.
If door panel is removed, direct power (+) and ground (-) can be applied to the motor to see if it raises; looks like power to motor's Blu wire and ground to Red wire. Only apply power and ground briefly to not damage motor if it is not faulty.
If you're still under warranty, refer issue to dealer.
hallstevenson
07-31-2013 07:00 PM
Michael Bomes
09-09-2012 04:12 PM
stillearning
02-28-2011 10:35 AM
01Accord01
04-26-2010 10:08 PM
siggy
06-15-2006 04:55 PM
