2017 Honda Accord Hybrid Front Grille Replacement
Hello
I have a 2017 Honda Accord 4 door sedan (Hybrid) and need to replace the Grille. The OEM appears to be in 6-7 different pieces and expensive. I have seen some other options, but some say they do not fit the hybrid. I am wondering what the difference would be between the Hybrid and Non-Hybrid. The options are either after-market grilles or used grilles - but need to determine if the Hybrid is specific and some of these other options really won't fit. Anyone know?
Thanks,
RQ
Thanks,
RQ
Are you referring to the upper grille or the lower bumper grille?
The Hybrid grille is different than non-Hybrid.
For example, the Hybrid lower bumper grille mesh is separate from the outer grille. On non-hybrid, the mesh is not a separate piece.
The Hybrid lower grille pieces doesn't all need to be replaced if they are not all broken. There is molding piece too.
I am referring to the upper grille - there is a base and 3 different chrome trim peices that attach to it, along with the Emblem (which mine is still ok)... I see a Sport Grille (one piece) 08F21-T2F-100 but not sure it will fit even though it says it does on one parts site - but it also says it fits the non-hydrid, so a little skeptical...
the parts I think I will need are 71121-T3W-J52, 71124-T3W-J51, 71123-T3W-J51 AND 71104-T3W-J51 so adding all those up is over $600 worth of plastic...
Thanks,
RQ
Thanks,
RQ
I'd look for used parts. Ebay is an option. Also car-part.com is a site that searches junkyards that list parts on the site by distance or price. I'm not sure if car-part.com will list the grill as an option, but you should be able to locate yards with 2017 hybrids in your area.
