5spd Transmission Oil??
Old 07-20-2006 | 01:50 PM
joe592's Avatar
Default 5spd Transmission Oil??
2000 Accord 4cyl. 5speed Manual Trans. Is it ok to use Mobil1 10W-30 in the transmission, or what would you guys recommend?? Does it make a big difference at all? Thanks, Joe.
Old 07-20-2006 | 03:08 PM
lightshow's Avatar
Default RE: 5spd Transmission Oil??
thats exactly what i use in my 91 5 spd
Old 07-20-2006 | 03:25 PM
joe592's Avatar
Ok, good to hear. I've already put it in a few weeks ago. Once in a while, usually when it's cold, shifting from 1st to 2nd I can feel a little vibration on the shifter as it goes into gear, kind of feels the same as if the gear was grinding but no nearly as violent, and no noise, I'm not sure if the sync is gettin warn or wut. I'd notice that way before I changed the trans fluid, and it didn't seem to change at all after I put mobil1 in it so I'm not sure if this is normal or what.
-Joe
Old 07-20-2006 | 09:06 PM
Chiovnidca's Avatar
ORIGINAL: joe592
I bet if you filled it with honda mtf that would go away.
Old 07-21-2006 | 05:52 AM
deserthonda's Avatar
did all this start after you replaced tranny fluid ? or was it there before ?????????
I would do as CHIO suggested, drain the tranny fluid and put some Honda MTF , see if that helps
Old 07-21-2006 | 11:46 AM
joe592's Avatar
It did it before, when it had Honda MTF, and it didn't change at all when I put in Mobil1
danielbeltran
07-01-2014 06:26 PM
iStagl
11-07-2011 11:59 PM
MiyashiMeism
09-05-2010 03:12 PM
DrumProdigy83
05-03-2005 01:28 PM
DrumProdigy83
04-23-2005 03:00 AM
