'85 (w/ carburator) dies once on startup every time
Hi All:
I inherited the car a few years ago and fixed it up some w/ a rebuilt head & new fuel pump & relay because it seemed too good to just toss out. It runs fine but the weird starting still eludes me. it used to die at stop signs too but I jerry-rigged a bypass on a vacuum solenoid that's supposed to boost the engine to overcome power drain by the AC, so that it's always on. Now once it warms up for a minute it usually runs ok, but it's a workaround and not a solution. gets about 23 mpg on back roads (the only kind we got here), & up to 31 on the freeway.
I kind of suspect that the problem is a vacuum pot attached to the choke, ok let me qualify that: That vacuum pot seems ok but somewhere there are valves that turn it on, such as the AC boost, & I suspect there are other conditions where it should engage too, like startup. Does anyone know where that valve is? other suggestions?
thanks
thanks
HashGobbler420
06-08-2012 08:00 PM
meditativecruiser
04-14-2011 09:09 PM
elfucer26
07-09-2010 09:40 PM
DRJIV
02-10-2007 01:11 AM
