87 accord heater controls
Old 12-31-2006 | 06:08 PM
mdjbhouse
Default 87 accord heater controls
The heater control on my my son's 87 accord provides heat only when it is on high, meaning the other settings don't do anything.
I saw a post somewhere else that mentioned something about a resistor pack that might be the problem.
Not sure if that applies to this vintage model or not.
Would I need to try and take the dash apart to get in behind the heater control levers?
Any tips or feedback appreciated.
Old 12-31-2006 | 07:38 PM
deserthonda's Avatar
Default RE: 87 accord heater controls
no need to remove dash or heater blower........resistor is located on top of blower assembly,, 2 phillip screws .call dealer ask for a blower motor resistor..
Happy New Year
Old 01-04-2007 | 08:34 PM
mdjbhouse
ORIGINAL: deserthonda
Happy New Year
I seem to be having a bit of a problem...
I found the 'blower resisitor' which is located under the right side of the dash behind the blower motor.
I removed the 2 screws which held the old one in place but now it seems like whatever was on the other side of the opending to screw the 2 phillips screws back into is no longer there or in position anymore.
I mean I can feel some sort of plate or metal flap that is up there (on an angle so maybe that got shifted somehow) but I have no visibility to see what is going on nor do I know what I should be screwing those screws into.
I thought it was just an empty hole but that doesn't seem to be the case.
Clear as mud?
Any help appreciated.
Old 01-04-2007 | 08:46 PM
sir_nasty's Avatar
Here is an exploded view of that area.... might make more sense.... Gotta love those vendors!
http://www.hondapartswarehouse.com/p...t6=B%20%201702
Old 01-04-2007 | 09:33 PM
mdjbhouse
I did manager to find something similar that showed me an explode view so I figured out I had just bumped the internal housing which I needed to screw it into. Not the best design in my mind but it is now working!
Thanks for the help all.
j894
02-08-2014 07:41 PM
WI2003Accord
01-19-2012 08:27 PM
Dan Fulmer
11-06-2011 01:34 PM
AccordEX6
06-30-2006 01:01 PM
