87 Accord LX - Gas in Oil -Won't Start
#21
First, I am not trying to run you in circles. I'm one of those that wants to be more than 90 and closer 100% sure of something before replacing parts.
You can "hot wire the pump" several ways, if you do and you are getting drops of fuel in the area I circled, then we are pretty sure the fuel is not being cut off by the float. I too was confused by the sight glass, what I figured out was that it was filling up the bowl before I could jump out and watch it. So it looked empty when in fact it was so full it was above the sight glass....if you know what I mean.
#22
When I removed the brass level adjuster it was very loose, I could have unscrewed it with my fingers, I'm pretty sure the o rings were leaking and that was the problem.
Test Drive tomorrow, fingers crossed.
Thanks poorman for your help, the vice grips on the hose was a great suggestion.
#23
GLAD you got it........again sorry for the run around but I/we like to do our best to test things before telling some one to replace/rebuild/ect..........
And I do lean towards the 3rd gen's......so I'm happy to know another one is back on the road (or should be soon)....
PS-once you get the float level set where you like it, borrow some nail polish or something and "paint"/lock the set screw-the top part....should have seen the yellow paint on the screw head.
Again, thumbs up to you
#24
Thanks again poorman for your help
Sheri6889
06-17-2015 08:19 AM
txredrage
01-08-2014 10:52 AM
