88 Accord no dash lights
Old 10-09-2012 | 08:30 PM
cj8281's Avatar
I tested all the fuses with a meter, all are fine. I grounded out all three connections in the dimmer and no dash lights. I tried tying any and all of the three connections together and nothing. If I ground out any of the red wires, the dash lights come on full bright. If I ground out any of the Red wires with the Black stripe, I have to find another 15 amp fuse, LOL.
Old 10-10-2012 | 06:01 PM
So you ground the wire and the lights go full bright....So we know the gauge lights are working.....they are not getting the proper signal from the dimmer.
Old 10-10-2012 | 10:25 PM
cj8281's Avatar
Yes that is right. The dimmer switch is no longer connected in the lighting circuit. When I get a few minutes I will check the wiring to see where the wires go from the dimmer and see how they are connected into the harness. If I don't have time I will make something work with an after market dimmer and a little cutting and splicing.
I have not found the dashlight brightness control unit.
Vettress
07-07-2010 11:10 AM
natthefisherman
04-12-2010 11:20 PM
eccsc01
02-28-2008 07:07 AM
marky4
09-07-2006 01:25 AM
marky4
09-05-2006 03:21 AM
Quick Reply: 88 Accord no dash lights
