88 honda accord heater only gets power with key at on I position
Like i said heater only blows when the key is between off and on I or on on I wile i push the key. I removed my tumblers with no problem theres nothing wrong with them. And the inside of the actual ignition is clean. Its a 88 accord 4 door with a brand new motor so i can drive it forever unless it rains cauae my defrosters will only work with key on engine off. I checked the power wire bleow the stearing wheen where all those wire clips are and i have no power to the main heater wire with the car running.
Not sure about 88 model, but later Accords have a ignition switch assy driven by the mechanical key lock assy that wears out. It is a frequent cause of electrical problems; no start, sudden stoppage, etc. This switch assy is directly linked to the key switch assy.
Check tegger.com for more guidance.
cchandler
01-23-2013 11:27 PM
ali.j
10-07-2009 10:35 PM
