89 LX-i Smelling fuel
The other day I was buying some dog food and when I got back into the car and started it up I got a massive fuel smell inside my car. It seems to be really bad like that when I start it up warm, but it doesn't happen every time I start it warm either, maybe one in 5 warm starts. It still drives fine and the smell goes away once I start driving, so it seems like it is a start up issue more or less.
Otherwise starting it first thing in the morning or after work I don't notice a gas smell in the cab and it drives fine. However once I park it I can sometimes smell a very faint gas odor outside of the car.
When I get the strong smell upon warm start up I pop the hood and try to see or smell where it is coming from but I can see anything obvious, then again I don't really know what I'm looking for other than cracked or loose hoses.
I think I might start with replacing the fuel filter? Unless anyone else has a better idea. Now all I need to do is figure out how to do it...
Check carefully around each fuel injector where it joins the fuel rail for leaks. Sometimes easier to smell/feel than see.
Check fuel supply line from fuel filter to fuel rail and return fuel line for leaks.
I am sure Texas' "next step" is right.
Yes, the air filter. If the smell is very evident in the air filter housing it would indicate a leak into the intake manifold or something to do with the throttle body. If the gas smell is not in the filter housing, it is likely to be a gas leak "to the outside." For instance, a fuel line.
So far it smells like the problem is near the first injector (the one closest the oil cap) or maybe a few inches to the left or it. I'll try to get a better look when it stops raining, but last time I looked I couldn't find a loose or worn hose, or any obvious signs of a leak.
Could a failing injector smell up the place like that?
