8th gen accord 2.4 petrol k24z3 vtec or VTC issue...
Hi all, car was recently bought from person who import cars from abroad car is located in europe so its for european market engine code k24z3 manual gearbox accord,
Oil and filters are changed less than 1000 miles, 0w 20 oil ravenol, with wolfram additive. my question is car is extremely slow,
vtec doesnt kick vtc as well,
car is feeling like 100 hp, no checks no dashboards or error messages... filters are changed oil as well,
according to the several shops , car have been sitting for very very long time, due to this probably it was driven with bad terrible fuel,
right now when car is driven on a high way strange noise is heard from the front i am guessing injectors - it sounds like or simular to raining, car is with fresh fuel , but it doesnt help, also what additives should be used will they help or petrol fuel filter should be definetely changed?
IF vtc is blocked due to previous bad oil and other things can it be fixed or it need to be replaced from scrapyard?
Also when car oil was changed oil was very black and burned also car buns oil no idea how much yet. since it has not been driven more than 400 miles since last oil change.
i cant verify or see when was the last oil change since the car speedo was clocked so no idea how much miles it into the moment the car it self.
Any helpful information will be great or advices.
Should i try amsoil p.i and other additives will they help ?
Many items can cause power loss. Injectors don't make much noise even when not working.
Do you hear the noise when driving at lower speeds? Does the noise remain when at highway speeds and you put the car into neutral?
Do you have a scanner that can read live engine data?
The noise can be heard when i press gas pedal and its coming from the injectors according to the work shops, several already confirmed i was inside the car,
in high way car is driven at more speed so more fuel is needed from the injectors etcs, in the town when i drive at low speed this noise is not there but car is still very slow it doesnt matter city or highway no holding or seized brake/calipers or issues with exhaust...
i dont have scanner but according to dealership equipment car doesnt have any errors or issues...
when i put car into neutral no noise only when i drive it at speed 100km/ or more..
bladest
07-18-2021 02:13 PM
