90 Model AC problem
Old 08-30-2009 | 10:36 PM
ditchdoc1017's Avatar
Default 90 Model AC problem
Just brought a 90 Accord having AC issue it push the button stalls engine . Also noise on start up.Can I just remove the belt looks like its a AC only belt.Also check engine with S light blinkingorder a speed sensoroff ebay.
Old 08-31-2009 | 11:03 AM
Any ideas can i pull the belt and leave it off?
Old 08-31-2009 | 11:50 AM
If that belt ONLY drives the compressor, then you're OK. Make sure whether the same belt drives the alternator.
Old 08-31-2009 | 11:56 AM
deserthonda's Avatar
same belt does drive alternator,,,it has 2 belts,,, 1 drives alt/a/c, the other the p/s pump ,,,,,,,,,sounds like the a/c compressor is locked up
what are the codes for engine and S lite ???
Old 08-31-2009 | 12:55 PM
I got out there seen PS hose . Oh well guess compress well have to be changed.Also "S" light blinks and check engine on orderd a VSS will change it to see if the speedo works.
Old 08-31-2009 | 02:06 PM
If that belt drives the alternator, then maybe you can get a belt for a 1990 Accord DX (doesn't have AC). That is, if you want to postpone fixing the AC...
Old 08-31-2009 | 07:31 PM
Thanks Might look in to that.
bhanuselvi
01-09-2006 03:27 PM
a1orientalrug
11-17-2005 06:07 AM
Mobile05
05-19-2005 07:03 PM
01-07-2005 12:35 AM
