91 Accord A/c just stopped working
Old 11-19-2005 | 05:43 PM
jayallen40
Default 91 Accord A/c just stopped working
The a/c on my 91 accord just stopped working all of a sudden. The compresor is not comming on I have checked the fuse in the fuse box in the car it is ok. I think I had a slow leak. Is it possible the freon gotto low so the compressor will not kick in?
Old 12-04-2005 | 11:46 PM
deserthonda's Avatar
Default RE: 91 Accord A/c just stopped working
if u are very low or no freon at all a/c compressor will not engage.......jump the high pressure switch at the rec drier ..if compr comes on most likely u are low on freon,,,,,,, another test ,, remove the recharge cap from the high pressure ( discharge hose ) hose, stick a small screrwdriver on the valve to depress it and see if freon comes out with a lot of pressure ,if hardly anything coming out recharge a/c , put a/c dye and chk for leaks..
19962door
05-07-2012 01:43 PM
foxylady23
05-19-2009 02:13 PM
dbennett3
08-12-2008 12:49 AM
88COMMUTER
05-26-2005 11:03 PM
