91 Accord EX 2.2 L Auto Sticky Ignition
Old 07-01-2012 | 12:39 PM
gjs@air-pipe.com's Avatar
Default 91 Accord EX 2.2 L Auto Sticky Ignition
Searched the threads but saw no reference to my question. The ignition switch has become increasingly more cranky on this unit. I have to move the steering wheel slightly to the right while moving the key around and turning it at the same time. Sometimes the switch is more cranky than others. The car has 240,000 miles so I am wondering if old keys may be the issue. Is this generally an issue with the key cylinder or is there something in the mechanics behind the cylinder that may be the issue ?
I would like to think I can just replace the key cylinder and be on my way.
Thanks, Galen.
Old 07-01-2012 | 04:00 PM
Might dry some "lock-ease" spray to see if that helps.....just an idea.
Old 07-01-2012 | 06:58 PM
Worn key may not push the lock pins far enough to open the lock. You can get a new key cut by Honda from original codes (I think Honda can supply the key code).
Or you can install new lock assy w/ new keys.
I like PM's suggestion combined w/ a new key.
ovukelj
12-15-2015 11:56 PM
bnewall1
06-22-2015 03:24 PM
Hescock2001
04-11-2014 11:26 AM
shehadehd
09-20-2012 05:20 PM
technical_sedan93
05-09-2005 12:02 AM
Quick Reply: 91 Accord EX 2.2 L Auto Sticky Ignition
