91 Accord EX MT Vacuum hose 3- Where does it go?
Old 08-20-2012 | 10:26 AM
slidewinder's Avatar
Default 91 Accord EX MT Vacuum hose 3- Where does it go?
I had a vacuum hose leak which caused my idle to act erratically. I found a cracked hose so I bought a length of hose and decided to replace all of them. When I looked at the hose module I found hose #3 to be not connected to anything outside the module, it just hangs there. I replaced all the rest of the hoses and It is still running at 1200 rpm unless it is really hot at which time it drops to around 900 RPM. I live in So. AZ so 100 Degrees+ outside is normal this time of year. The manual and the under hood diagram are confusing and there is no place to hook it up that I can find.
Should I plug it? (It is sucking air) or has it been wrong since I bought the car 4 years ago?
If it needs to go some where, then where and what does the part look like?
Old 08-20-2012 | 10:30 AM
I moved this from the DIY section to the General Tech Help section. Please do not post help questions in the DIY section.
Old 08-20-2012 | 07:33 PM
On the diagram, can you tell us the two components that the #3 vacuum hose should connect to?
Old 08-20-2012 | 07:46 PM
http://www.autozone.com/autozone/rep...00c1528005f7ff
Identify vacuum hose in this diagram and you should be able to reconnect. I think diagram no. 32 is yours.
Old 08-20-2012 | 10:24 PM
Look like it goes to the evap......
Attached Thumbnails 91 Accord EX MT Vacuum hose 3- Where does it go?-4th-gen-mis-vac-line.jpg
Old 08-20-2012 | 11:06 PM
Thanks all,
I found that the last owner had broken the input to the canister. They did not do anything with hose #3 or the canister. I drilled out the canister hose fitting (at least where it once was). Then Jerry rigged a small hose into it (canisters cost a fortune and It is 21 years old). I have inserted the small canister hose to hose #3 and put RTV all around the connections. hopefully they will not leak. I will know tomorrow. If it holds then I should get a good seal and be able to adjust the idle to 700. I was not expecting the fitting to be missing, which is why I could not find it. I'll let you all know the outcome. It's always a challenge when you have an old used car. Thanks again.
Old 08-21-2012 | 06:51 PM
A few trips to local bone yards might help....try car-part dot com for local yards that might have an Accord in that gen you can go visit.
packrat79
08-31-2012 03:52 PM
jtkj
11-09-2009 12:42 PM
skinnytexan
10-17-2009 09:21 PM
Antarctica
10-29-2008 01:53 AM
mak
03-29-2008 09:11 PM
