91 Accord Passenger Window/Auto Seatbelt
I have a 1991 Accord and the passenger automatic seatbelt (the one that pulls back as the door closes) gave out and the window won't go down. The seatbelt doesn't pull back when the door closes. The light on my dash that displays which doors are open, shuts off when I close the door, so it's not the door sensor. I checked all the fuses and relays I could find and still had no luck. My dad installed a new seatbelt assembly, and had the same results. As for my window, it only seems to roll up. The motor turns when pressed "up" but does nothing when pressed "down". My dad and I checked all the connections, and the switch gets continuity for the appropriate motions for "up" and "down". We checked all fuses and relays we could withno results. My dad put in a whole new window motor and it only responded when pressing "up". Any ideas on what else could be going on?
andx0r
07-18-2013 08:54 AM
1LordAccord1
06-19-2012 08:33 PM
Mott23
08-04-2011 10:33 PM
erikahad
02-04-2010 08:01 PM
