91 accord runs rough when hot
Old 07-09-2009 | 10:06 PM
hondarider753's Avatar
no the check engine light does not come on but could it still be one of those sensors? or would the light come on?
thanks
Old 07-09-2009 | 10:46 PM
Those were just two examples. The check engine light should come on if a sensor's reading is outside of some preset range. A large range could allow a flaky sensor to not trip the Check engine light.
I had a flaky throttle position sensor that would occasionally trip the check engine light, although it was messed up all the time.
You should check for codes just to be thorough.
Old 07-10-2009 | 07:44 AM
Does the check-engine light come on for 2 seconds when you first turn on the car? (Bulb-check)
Old 07-11-2009 | 12:59 PM
yeah it comes on when i turn the key on and when i short out the connector it just stays on doesnt blink...
Old 07-13-2009 | 08:17 AM
OK, staying on solid when you short the connector means the bulb is OK & there's no codes stored.
RicRoc
07-28-2013 09:18 AM
Doug Sample
06-30-2011 12:55 AM
chris30721
01-06-2011 09:06 AM
JoetheEngineer869
03-31-2010 07:57 AM
Accord Pete
01-31-2010 03:50 PM
