91 Accord Slips Out of ALL Gears after 30 seconds
you can't change the trans filter. It's non serviceable. You have to tear down the whole trans to get to it. Also when you drain and fill clean the drain bolt. It is magnetized and will collect most of the metal shavings. Just make sure to wipe it off really good be4 you re-install it.
The 4th generation accord automatic transmissions were pretty solid. You might consider buying a low mileage one at a junkyard. car-part.com can search for parts by price or distance. The cost may be much lower than a rebuild.
No need to be a dick. I'm simply having a conversation and asking questions. I appreciate the help. I went to auto school years ago, but only worked the trade for a short time. Since then I've fixed all of my own stuff with good success. I've never rebuilt a tranny, however, and the Honda's are a new animal for me.
As it turns out, you are right. The trans is getting worse. Looks like a rebuild.
How do I find the exact model number for my transmission? I have the old tranny that came with the car. All that is wrong with it is it wont go into reverse. I would like to rebuild that trans and fix the reverse gear (and whatever else related to that). Anyone here do tranny rebuilds? This will be my first.
There should be a white tag with 4 letters on it close by the starter or so , like BAXA, BMXA or MDKA something like that. You will need air tools and footpress or hand press tool, they will make your life 100 times easier if you are going to rebuild it.
#17
[quote=DragonHeart335;249908] BTW, there is no clutch "material" in a torque converter. It is a fluid coupling device, all metal.
You guys probably heard of a code PO740 Torque converter clutch malfunction ? Very common in the automatic transmission, or TCC slip or torque converter clutch slip ? Here are the some different type of converter clutch, they have single or double springs lock-up clutch, paper clutch, woven clutch. 90-99 Accord uses clutch type without coast release torque converter. Here are some pictures for you guys ImageShack Album - 4 images
Honda Enthusiast
11-06-2010 01:33 AM
