'91 Accord speedometer/odometer quit
Old 03-13-2008 | 08:32 PM
pfrathjr
Default '91 Accord speedometer/odometer quit
The speedometer and odometer only work for brief periods. Any ideas? Thanks!
Old 03-14-2008 | 02:45 PM
accord4sroy's Avatar
Default RE: '91 Accord speedometer/odometer quit
Well, a lot of folks on here have mentioned a bad VSS (Vehicle Speed Senor). So, that could possibly be the issue. I am sure more responses will come soon. A lot of knowledgeable people in this forum.
Old 03-14-2008 | 04:50 PM
00AccordLX5spd's Avatar
Registered User
See if your cruise control works when the speedometer doesn't work. If the cruise does not work when the speedometer works, it is probably the VSS. If the cruise control still works when the speedometer doesn't work, then it is probably not the VSS - it is probably something internal within the speedometer.
Also if you have a bad VSS your check engine light should be on.
Tony1M
11-06-2023 09:29 PM
BSims66173
11-09-2012 12:52 PM
9DEX
10-09-2011 09:46 PM
jackmd
09-15-2011 07:11 PM
Driver 1
05-26-2011 12:33 AM
