91 accord vss not working
Old 08-01-2012 | 12:19 AM
Raśl C's Avatar
Default 91 accord vss not working
I couldn't figure out how to add my car to my garage, but I have a 1991 Honda accord Ex 2.2 L. Since i received the car the speedometer jumped around a lot. I touched the wires on the vss to try and locate it and after that it completely died on, reading at 0 no matter what. I got my hands on 4 different (scrap yard) sensors and exchanged it. It worked fine the first day then it started reading at zero until i had driven for about ten minutes. After that it would work fine so i decided to switch it again but now the spedo stays at zero even after driving for an hour.
I checked to see if the tiny rod that goes into the sensor spinned without the sensor on and it did. I also tested the black and yellow cables and they both seem to be ground, this is what im guessing the problem is. I dont know what else to check any help would be appreciated. I hope i make sense im very sleepy and i dont think im writing cohesive thoughts.
Old 08-01-2012 | 07:43 PM
A bad connector? You "touched" the wires and things went bad. Go back to the bone yard and get the harness that goes to the VSS.....splice it in - be sure you have a good connection. See what you have from there.
Old 09-12-2012 | 11:40 PM
Raśl C's Avatar
So you were right, I came home the day after this post and the car had been taken to the mechanic(much to my wallets distress). The mechanic ignored everything i had already done and put a new vss, different cluster and when all that didn't work he checked the cables that connect to the vss and found the problem. Had i had that car one more day i would be 100 dollars less poor. Anyways thanks for your help sorry for the late reply.
Old 09-13-2012 | 05:46 PM
My pleasure......glad you are back in working order, less the cost.
Thank you for coming back with the answer, it helps the next person that does a search......
Joetime
11-06-2022 02:37 PM
mrmiller99
09-27-2019 02:26 AM
PeteGibson
06-27-2014 02:34 PM
mrmiller99
07-02-2011 07:07 PM
comptoncarl
02-08-2007 03:04 PM
Quick Reply: 91 accord vss not working
